Laser will not fire after 1.09 upgrade
I just upgraded my oneinfinity and now my laser will not fire I have the Jtech 7 W laser
I have tried that M3 S08 command and even raised the S08 to S40 Still nnothing
I went under tool and click Jtech
still nothing
please help
Did it fire on 1.0.8 and below?
  • Changed pwm spindle speed for jtech laser from 255 to 1000. Since spindle speed is increased, you will most likely need to increase the S value (m3 sXXX) you have been using in the mdi command to fire the laser. This S value should be anywhere from 1-100 (100=10% power). If using lightburn, you’ll must to do this for the laser to work correctly : S Value for Lightburn with Jtech Laser
via the update faq. 40 might not be high enough as it was 15.6% and is now only 4%.
So under the tool option I do not choose the jtech laser eye continue with the pwm
It works thank you, however now my joystick does not
