Hi, since there are well-known challenges with wi-fi connectivity and throughput, how about simple steps to lighten up the web UI?
For example, compressing the image files used in the web UI seems worthwhile. I compressed the standard image folder to test. The original set of images was 532k, but it was easy to get them down to 168k, with no noticeable quality loss. Roughly 1/3rd the file size!
You could also get the index.html down from 3.0 MB to roughly 2.6-2.8 MB just using an HTML minimizer.
I know that browsers cache images, so I tested before/after using web developer tools.
Before (original images) loading the images in the web UI took 18167 ms, or ~18 seconds.
After (compressed images) the images took 835 ms, or <1 second.
I tried to use identical A/B environment as best I could.
Regardless I think there’s lots of room for improvement in terms of making the web UI a lot lighter, which could improve users frustration when using the Web UI.
