Machine boundary not accurate from carbide create gcode file
Hello,
I am having a problem that involves when i upload my gcode file to the onefinity, the images (ive tried a few files) are automatically moved to the edges of the boundary, if that makes sense. Never had this problem before.
for example, an image that is centered on a piece of material will now be moved to the top and right edges of the boundary on the machine.
anyone know the solution?
all the best
Original image
The outline of the material on the 1F screen is not the size of the material in your CAD software. The 1F image only outlines to the limit of the machining. There is no gcode parameter telling the 1F how to draw the stock.
