I was wondering if I’m doing this right when I save my tool path.
Will this setting work for my Onefinity.
Machine file format : G-code ( inches ) *.tap
Sorry all new to this cnc stuff.
Thanks
Hey Terryjames,
which CAD/CAM software are you using?
This is wrong, see here:
The controller can only open/see a few file types. Ensure the file your trying to open is gcode and ends in .ngc , .nc , or .gcode . The controller will not recognize non-gcode files, such as the CAD (design) file you make gcode with (for instance, If you are using Vectric VCarve and you hit save in the upper left, it creates a file ending in .crv . This is the design file not gcode and the controller will not recognize it.
See also:
Does not read tap files
Hi
I’m using carveco. I have the controller box from Onefinity
Hey Terryjames,
Then you should use the Onefinity-specific postprocessor:
Carveco : Comes in several types, some subscription based. Does not have trial version. Has Onefinity Specific Post Processor. We sell it HERE.
Further Reading
Sorry carveco maker I have. Bought it with my machine
Hey Terryjames,
Great.
All you have to do is to choose the Onefinity postprocessor.
mitzpellic
(Mitz Pellicciotta (community moderator))
May 23, 2022, 11:54am
7
Use the drop down arrow on the machine file format line and select Onefinity (either inch or mm).ngc
I use the one labeled OnefinityNoToolchange.(inch.ngc)
Hi
Thanks for the help !!
