Toolpath files not recognized by network or USB
I have my Onefinity Forman Pro controller connected to my WIFI network and am trying to load ngc files, but they are not recognized by the CNC. When I navigate to the location that has the files, the controller shows a blank directory.
My steps:
  1. Created a flattening toolpath in Carveco Maker (first job on this machine, flattening my spoil board)
  2. Clicked the “Save Toolpaths” button
  3. Selected “Onefinity - BB (inch) (*.ngc)” for the machine file format (I’ve tried metric as well, and have also creating the file using the Elite option - same behavior)
  4. Gave the file a name of “flatten”
  5. Selected a folder on my desktop called “CNC”
  6. Clicked the “Save” button
  7. Confirmed the “flatten.ngc” file exists in “C:\Users,my_user\Desktop\CNC”
  8. Opened a browser and navigated to the IP address of the CNC controller
  9. Clicked the upload/open button
  10. Navigated to “C:\Users\mikes\Desktop\CNC”
  11. The folder appears to be empty
I’ve also tried the process using multiple USB drives of different brands and sizes, as well as have followed the troubleshooting steps located here:
The behavior is the same with a USB drive.
I’ve also tried *.nc and *.gcode extensions but haven’t had any luck getting files to show up in when searching for them from the controller.
I have also tried multiple local networks. Everything else works remotely, such as homing commands, jogging and power/rebooting.
I’m running version 1.4.0 firmware and checked for updates - this version appears to be the latest. I’ve power-cycled many, many times.
Anyone have any ideas I can try by chance?
Thank you,
Mike
There are two buttons, one for upload folder, one for upload file. Which are you selecting?
I have tried both, but now that you mention it, folders aren’t showing up in the controllers file/folder upload dialog, either. For example, I put a few *.ngc files in USB the root, as well as in a directory called “toolpaths”. When I select either upload file or folder buttons, and then open the thumb drive, I don’t see the files or the folder.
As a test, I tried to create a folder on the USB drive from the upload file dialog (the folder icon with the + on it) but got a permissions issue. I have some new USB drives on the way so I’ll give them a shot. I’ll also try troubleshooting my local network and the PC I’m using to connect to the controller. There might be a network or firewall setting that’s causing the issue. I’ll post an update as soon as I have one.
Thanks!
Mike
Hey Mike,
If you click “upload” on the Onefinity User Interface in a web browser on a remote computer, you should get the usual “Open file…” dialog on your computer, which allows access to the entire filesystem of the remote computer.
In the “Open file…” dialog, maybe you have a small button on the right where you can select “All files”.
Welcome to the forum!
