Make a Heart-Shaped Lidded Box | Valentines Day Gift Idea
Happy Valentine’s Day, friends!
In today’s project, we’re making a simple heart-shaped lidded box. This one is super easy doesn’t use much material, and filled with the right stuff, will score you major points with that special someone.
Download the cut files for FREE here!
Heart Shaped Box Cut Files.zip (1.5 MB)
The main goal of this video, though, is to demonstrate a good method for making lidded boxes of any kind. So whether it’s for Valentine’s Day or Festivus, this is a great way to present a gift!
There’s an optional part to this project. Morgan incorporated a custom music box mechanism into his box. The supplier offers the same mechanism with thousands of other songs to choose from so, if you’re interested in taking that extra step, check out Custom Music Boxes Online Store - Miium®
Have a great holiday, we’ll see you on the next one!
Any way to get the files for Vcarve PRO?
If you have Vcarve PRO v12, you can download Morgan’s zip file. If you have an older version, you will have to follow Morgan’s instructions from the video.
What version of Vcarve do you have?
Dirkus
I do have Vcarve Pro v12, but the only file that opened was the SVG. I couldn’t open the crv3d or import it.
Here is a Vcarve 11.5 box you could use as a starting point.
HeartBox4.crv (3.6 MB)
I also have it as an Aspire 11.5 format as well.
HeartBox4.crv3d (3.6 MB)
I hope that this helps.
Dirkus
Thats awesome! Thanks. I tried making a box before but could never get the lid to fit corrected. Always too tight.
very nice work. an inspiration. question: what are the dashed frame lines at the edges of the work piece?
James,
The dash lines are just guidelines I used to position the model on the material. I wanted to keep a solid material frame to keep everything together during milling. The guidelines are inset 0.3 inches from the edge of the material. This allows the 0.25 end mill to cut the profile of the box without cutting the material edge. I did this because my preferred clamping method is from the sides of the material.
Dirkus
very nice work!!!!!!!
I used magnets for the lid too and they worked great —just made sure to flip the polarity on one side so it snaps shut properly and doesn’t repel by accident.
