You can plug the keyboard into the open internal USB port. I have a wireless USB keyboard dongle plugged in there, and I just leave it in all the time. This allows me to use the keyboard whenever I want and kept the external USB port open for the thumb drive.
Thank you. I’ll try that.
So the F1 button on the Masso touch screen quit working?
Pat
No. The tapping the screen to enter the firmware loading screen quit forking. The F1 soft-key probably works fine, but that’s not accessible prior to boot.
@RickDuVall make sure the firmware file has the .HTG extension. The 5.07 version filename is G3-16963 - MASSO 5-Axis v5.07, WiFi, Touch, QR, Multi-Head.HTG and make sure it is in a folder at the root level called MASSO.
So double check the USB drive and make sure the firmware file is in the MASSO directory.
I did not need to use a keyboard.
Hi Michael. Do you happen to know if Masso also have an Android app as well as an IPhone one and if so what the icon looks like. I can only find one app which mentions Masso and that app is called MASSO myWorkshop from a company called MASSO Australia. I don’t want to install that app if it’s the wrong one.
They do - here is the link to the Play store for it: https://play.google.com/store/apps/details?id=com.masso&hl=en_US&gl=US&pli=1
Yeah, it’s the legit one!
Hi Michael.
Thank for the extremely rapid reply, it’s very much appreciated. I’ve downloaded the app but I’m unable to login. There does not seem to be a page to set up an account. Tried the forgot password page but get a “Unable to generate OPT” message. When I try the login page and enter an email and password I get a “Invalid User Credentials” message. Do you have any guidance on setting up an account?
Hey @Redcap
I had the same issue until I realized that this is linked to your original purchase email. You should have gotten an activation email from Masso and in that email there is a link to follow to setup the Myworkshop account.
If that link has expired you can request a new activation link and just put in the correct email. A new email will be sent with a fresh link. With that you should be good to go.
HI Kemperle-Industries.
Many, many thanks for your reply email. It all makes sense now and is logical. As I haven’t purchased my CNC yet I haven’t received such an email. I’ll leave the app on my phone and activate it when I purchase the CNC next month.
Once again, many thanks for your assistance.
Kind regards
Karl
I went to do this update to 5.07, I have a PNY Thumb drive formatted and partitioned correctly, enter a Masso folder with the update file from MyWorkshop loaded in the Masso Folder, I insert the drive , turn on Masso while tapping the screen, the software load page comes up but indicates there is no software on the drive to install , I tried with two different jump drives.
Any ideas?
Thanks, Pat
Hey @PezWoodworks
Did you make the folder in all caps (MASSO)?
Also is your drive formatted FAT32 with the default Allocation Unit Size?
Yes, all caps and yes formatted FAT 32 , it is a 32 Gb
I used an 8GB drive when I did my controller, there might be a size limit. I can verify in a little bit when I’m at the machine.
The documentation says 32 Max and I use a 32 Gb to load files all the time.
Thanks, Pat
Did not fix my WiFi disconnect. The next morning I’m faced with the old “Connecting …” status. Irritating, but not a show stopper. Just wish they could resolve it.
Pretty sad that our expectations have been reduced to six continuous hours without a disconnect! I woke up this morning to see it disconnected, so … not fixed for me. I leave my CNC on and almost always, but not always, have to cycle it before a session.
I did the upgrade today from 5.06, and the odd problem I see is that now I can’t just go to f4 to switch tools, clicking “auto tool zero” on a new tool reports “tool not loaded” where it used to just test the new tool.
Have you posted this on masso forum or created a ticket with them?
They do not monitor these forums
I did post to their forum. So will see what comes of it.
