Masso file type
Using carveco maker +.
What file type should I use for my Elite Journeyman. I see the test file is a .nc, but none of the Onefinity options are .nc, and Masso does not read the .ncg that was recommended.
Select either:
Masso-ARC-ATC (inches).nc
or
Masso-ARC-ATC (mm).nc
Carveco is working on making a 'Onefinity Elite" post processor in the future…but it will literally be the same one as the above, just renamed for simplicity.
I am just creating the surfacing file for my Elite Journeyman and have run into a similar problem but am not using Carveco. I am using Freecad. Freecad does not have the option for “Masso-ARC-ATC (mm).nc.” My postprocessor is currently set for KeneticncBeamicon2. It produces usable Gcode but noticed that I am getting an odd offset for G 54 that is screwing up my cuts. The offset is x=609.91888 y=542.77392. Could the two problems be related? Is there a way to get the Masso postprocessor for Freecad?
Not sure if this helps. The link below was provided in a post by a Onefinity member:
https://forum.freecad.org/viewtopic.php?f=15&p=644059
Thanks. I am still struggling to figure this out.
cheers,
jrg
