wjbzone
(William J Barrows)
1
(ver 1.1.1.1)
I set my 1F to Imperial everywhere I can.
The Settings - Probe dimensions still uses metric offsets.
Overtravel error still displays metric range.
Biggest problem:
After every Probe Z, The MDI resets to metric. I have to issue a G20 to use MDI commands each time I use the Probe Z.
OnefinityCNC
(Onefinity CNC Official ✅)
2
The underlying unit in the buildbotics codebase is MM. The probe setting will always be metric (should only ever matter once setting it up).
wjbzone
(William J Barrows)
3
Using the probe Z changes the MDI setting (G20/21) every time it’s used. Have to re-issue a G20 MDI command every time after using the probe.
