I like your design. How did the build go? I’m looking to do something similar with the mine.
The build went great and the 8020 has worked flawlessly. I have linear rails on the wall I think and a structure of 8020 under the QCW with 4 8020 pivots for the hinges.
CHUANGNENG Linear Rail SBR16-1500mm Linear Guide with 2 PCS Linear Guide Rails and 4 PCS SBR16UU Bearing Blocks for DIY CNC Routers Lathes Mills, Silver (D458PF503LT141Y) https://a.co/d/0iR5VzN
80/20 Inc, 4197, 10 Series 0… https://www.amazon.com/dp/B013F30VYS?ref=ppx_pop_mob_ap_share
80/20 Inc, 4198, 10 Series 90… https://www.amazon.com/dp/B013F46IBW?ref=ppx_pop_mob_ap_share
Thanks for the information and links. I wasn’t sure what size linear rail I should get for the wall. I was looking at 25-30mm but they are hard to find at 1500mm for a good price and that may be over kill.
What did you use to secure the 8020 to the bottom of the QCW? I was going to use plywood to mount eye bearings and tube for the pivot arms so I could easily level the surface and the parts wouldn’t wear out from use.
I drilled through the QCW and bolted the 8020 frame underneath. It is rock solid.
