Does anyone know if it’s possible to change the resolution on the MPG Pendant? Defaults are 0.01mm, 0.1mm, and 0.5mm, would be nice to tweak those depending on how each individual uses the machine.
I think I also saw this come up as a feature request in the Masso forum many years ago.
I do not believe it is high on their list of features to add. This level of customization I think is where the other PC based controllers will always have an edge over Masso - for those that want or need that - as they need to always work within the constraints of their hardware memory limits.
Thanks guys, I’m new to the Masso world with this machine and scoured any info I could find. I figured it was probably a locked setting though
Yes, in the F1 screen, x-axis settings y-axis and b-axis settings (left column) you can change the pulses per revolution from 400 to 800. Don’t change the z-axis setting. [
