Need xyz probe help
Hello,
Looking for some help. I would like to know if I run a project with 2 cut files and separate bits sizes do I need to probe on bit change?
Thanks in advance
Short Answer, yes. But only for Z,
Otherwise machine will not know length of bit after change, and cannot accurately cut desired dept.
If more than one bit then you need to probe Z only on the second bit. XY is already established during the initial probe
Thank you much appreciated
Thank you for your help much appreciated
