Network direct cabling
If the controller is connected to the local network with an Ethernet cable, you should not need to worry about IP addresses. The controller makes itself available to devices on the local network at http://onefinity.local.
If your browser is unable to see the controller at this URL and you are running Windows, you may need to install the Bonjour print service and reboot. You should then be able to see .local URLs.
