Newbie trying to control spindle
Hi. Trying to get everything working - Fusion 360 to a Scienci labs T1 autospin router. The Onefinity test file worked well, it seemed to have the spindle commands, however, when I created G code in fusion 360 with the Kirbre enterprises post processor, it didn’t seem to have the spindle commands as the router did not turn on. Is there a different post processor or is there a setting I can modify in fusion so that when I generate G code it has the spindle commands automatically? Or am I missing some greater context here? Thanks
Use this one and see if it helps…
Thanks. I used this PostProcessor and found it was inserting a tool change command at the start of the program. Went back to the Kirbe enterprises one and I found that my problem was not specifying a high enough spindle speed (minimum S10000)
Happy it is working, and thank you for letting the forum users know your solution.
Going forward, I believe the best place to get current Post Processors is directly from RealTimeCNC.
