So I havnt done a ton on the CnC yet if I were to guess 10-15 hours run time, but this happened today. When I first set it up, there was one random oil drip that happened on the bottom main spoilboard on the QCW. One. Fast forard to today. I setup the second layer spoil board on top the bottom, and I ran the grid pattern from filefinity today, but I got another drip. I took a couple photos of where its coming from. I havnt done anything to the CnC as in oiled it, moved it, anything. It just happened to do this today. My question is, is this normal or is there something I need to worry about? Thanks!
I doubt it’s anything to worry about. As the bearing move back and forth they deposit oil on the linear rods. The wipers on the bearing will push the debris on the rods and some of the oil. Over time the oil can build up and drip if there was a little too much in the linear bearings.
Thanks, I was kinda thinking about this also, I dont run it the full area very often, so maybe the back and forth of doing the grid lines did this very thing.
I over did it with oil on mine and it has done the same thing
