is it time to replace something? if so what? I have seen a couple of videos about it on YouTube
was wondering if anyone has done this
Assuming you are talking about the ball screw oil ports. It is normal for the oil to run out while filling. It is the indicator you’ve added enough. It probably will continue to drip a bit afterward so I leave a paper towel under the rails to protect the spoilboard.
Are you seeing this beyond the service action? If so, that would be a new one on me that I can’t speak to.
i shoulve been more specific,i mean the oil is comming out from where the screw drive enters the plastic
Yup, that should happen.
If you follow the 1F video on servicing the ball screw nuts you’ll see why the oil will run out.
