My Onefinity cnc ,with no program loaded, will not home when I first turn it on. When I home it the “X” axis tool path column says “no fit” the “Y” axis tool path column says “under” and the “Z” says over but that is ok until I probe the “Z” axis. It homed fine until yesterday. I have always used the shutdown command so I don’t think I have messed anything up.
delete all files on the controller, reboot.
I have the small display that comes with the machine currently and I don’t see a way to delete the files. Sorry to be so thick headed but can you tell me how to delete the files off the controller?
Thanks
Thanks for this help. I guess it worked because the machine “homed” fine but when I pressed the file folder button all the files were still showing??? Is that normal?
