Decided to try pen plotting with my Gen 2 Elite Woodworker. I downloaded and printed a pen holder from Myers Woodshop Etsy then mounted it. No problems there. I’m using VCarve Pro, how do I set it up to draw within the program? Do I set my X, Y & Z the same as when using bits? What about the depth/pressure of the pen tip?
See my post here:
I describe my setup in detail. Hopefully, your new attachment is spring-loaded. I’ve had bad luck with those that weren’t.
In short, make a tool as described for your tool database. I’ve attached a picture of mine. Note that you’ll have to experiment with pass depth to get results from your particular setup.
Thanks Mike, I’ll give your settings a try.
Paul
