Can anyone share some useful tutorials or examples of how they have successfully trammed their onefinity?
I have a gen1 x-50 woodworker and I recently just upgraded it with a few new toys. I have a new stiffy third rail, z20, redline 220v spindle and HMI and a set of three airweights qcw slats. I would like to add an ATC as well if I can get this thing dialed in better.
I never really had much of a tramming problem with the old makita router and z16 slider so I don’t think I had to do much beyond putting a combination square up against the z slider.
That method does not seem to be getting me as close as I was, I do have a stupid simple tools tramming gauge, but the reality of using it to actually dial in the spindle eludes me.
The only adjustments I seem to have are the four socket head cap screws that mount the z20 to the gantry. I know there are also tramming adjustment screws on the x axis gantry blocks but until I get the z axis closer to correct I’m not sure they are too useful.
How in the heck is anyone else actually making adjustments in the range of .010” or even .100” with those z mounting screws?
To make any changes I have to go through so many steps,
I can’t actually access the bolts unless the z axis is in exactly the right position, so I have to raise the spindle up off the bed so the tramming tool is no longer providing a reading when I am actually able to loosen any of the bolts.
Further complicating things the weight of the spindle means I have to support it entirely with one hand and attempt to keep the z slider tight to a combination square while “hoping” manual adjustments are going to result in the tram readings improving?
Am I missing something? Is there even a real way to effectively tram these machines beyond “thoughts and prayers” and wishful thinking?
I’m not trying to be flippant but I am very frustrated. I love this machine and the build quality is fantastic, but I have scoured the internet and YouTube looking for anyone with a similar setup machine that has actually succeeeded in dialing it in with a tramming gauge and I’m coming up short.
I have tried a combination of 1-2-3 blocks and spacer blocks to attempt to get the z20 on the gantry squarely but the best I’ve been able to accomplish leaves the dial indicating a significant difference from one side of my airweights slat to the next in both left to right and front to back.
Because I have the airweights system I have the added complication and stress of having to run the vacuum pump the entire time I’m attempting this so that the fixture plate I’m testing off of is actually sucked down flat to the slat.
I honestly have a little buyers remorse over the full qcw slat system I purchased. I do like the airweights and I think they will serve me well, if I can get them dialed in, but they do make tramming more difficult. I think this would be a slightly simpler task if it were on an mdf spoilboard like I previously used and definitely quieter without the hot noisy pump running under the table the whole time.
If you have successfully trammed your machine I would love some practical tips or better yet a tutorial.
