Production of Multiple copies
Finally putting my onefinity to work. I have a project that will require multiple copies of multiple pieces. My plan has been to pre-cut rectangular pieces of plywood, and then mount them in a jig to let the machine make some cuts and drill holes on the parts. It all works fine, but the machine requires that I use the probe to set the Z axis before each piece. I zeroed out the x and y so the machine always knows where it is, but I don’t see why it can’t remember the z height. Running the probe routine each time more than doubles the time per piece.
Any help will be appreciated as I have to make 32 copies of 84 parts. Every second saved is a lot
Thanks
remove the m6 command from the code.
Perfect I figured there was something like that. Thank you
