Was wondering if anyone has the parameter setups for the pwncnc vfd?
I have a new setup Elite Foreman and pwncnc 2.2kw vfd setup.
spindle works under manual control, but just flashes and the display doesnt change nor does the spindle run.
Im trying to check what I can while I await pwn to respont to my support request.
I cant find any documents on their website with the settings for their VFD.
setup as per the included document that came with the set, s6000 sent, the masso display shows the s6000 and the cw but never runs the spindle
If you have the VFD enclosure make sure the switch is on Auto not manual . You should be able to type a speed into a box on the MASSO next to CW then press CW and the spindle will spin. This means you are in the correct mode.
works when in manual, switch to auto and no setting from the masso does anything on the spindle, display just flashes. Thats why I’d like the data to see if the VFD is setup correctly.
I got it all figured out with a combo of info from the postings here and with help from PWNCNC. I have the V3 enclosure, so I had to rewire my VFD and rewire the controller as well as reprogram as per the link you attached. Hopefully this will help someone else in the same situation.
