I am new. Have not even received my Journeyman or R-F stand yet. Can the Journeyman run while on the Rolling -Folding stand in the vertical position? Similar to a wall mount. I presume, if it can, stabilizing the QCW frame up high is necessary.
No, it cannot. Do not use it in this configuration.
Could you elaborate a little? Is it rigidity of the frame. Instability, or the Axis will twist etc?? Anything that could be overcome with some ingenuity?
It will absolutely not work as it’s not intended in any way to carve on the rolling stand. 100 different points of failure with this method. If you attempt this, even with applied ‘ingenuity’, your warranty is voided as you’re using it out of the manufactures specification.
Good to know. I am just thinking of different ways to work within the constraints of my space. While I wait for my order. Thanks
