Quick question on set up
Just set up the machine, turned it on and homed it. After a successful homing, I tested out the controller, moving the cutting head around and noticed that the X gantry stopped 2 inches from the back and would not go any further. No grinding sounds or funny sounds of any sort, just wouldn’t go all the way to the back.
Please post a photo.
I forgot to mention that I have it mounted to the OneFinity wasteboard frame
Welcome to the forums, Ken.
Check to ensure that you’re not moving in increments greater than the 2 inches, i.e. if you have it set to move at 5 inches, it definitely will not go another round. The controller knows all things. :wink:
Thank you, I will check it out
I’ve had similar happen. Since the controller boots in Metric, I usually switch it to Imperial and re-home. It’s a problem I have only ever seen upon initial startup, and re-homing in Imperial has always fixed it for me.
Awesome, thank you for this!
