Reloaded .htg files
My Elite Foreman started machining in the wrong location. I did the xyz probe routine and the Y axis moved away from the block instead of toward it. I assumed a static electricity issue so I ran ground wires to everything.
I pulled the .htg files from Onefinity then loaded and rebooted the machine. The controls on the Masso moved all of the axis in the right direction. Everything seemed normal.
I even generated a new file to upload thinking the old one might be corrupted. When I load a file and use the touch probe the Y axis moves in the wrong direction. Advice please. Homing also does not automatically reset the axis to zero.
Make sure you have selected inside our outside in the probing routine, I had the same issue and it did not seem clear to me at first.
Look at the graphics to tell if it is inside or outside.
Pat
Thank you. That fixed the Y moving the wrong way. Besides the machine being corrupted and the Y moving away from the probe I found the file corrupted.
I started the project over from scratch in Carveco and new toolpaths work.
