Resetting a carve
Hi all, I finally made a stupid error after almost two years. I set up a 3D carve but I forgot a step prior to the 3D roughing and ended up having the wrong bit in place starting the carve. I had done everything except the final cycle start and wanted to cancel everything and set it up again. Is there a “cancel” available? I could not find anything that would get me out of the carve, even the emergency stop. Eventually I resorted to a power off which I did not like. Any ideas? Thanks.
Hi David; What controller do you have? I know on my Redline there is a big red “Abort” button on the top of the controller screen while the program is running. I’ve had to use it a couple of times, it does what it says…
On my Masso I can rewind the Gcode.
Pat
