I reversed my X and Y on my Onefinity Woodworker. I mounted the controller and drag chains opposite of usual. Everything is good, except the Z mount on the x rail will not allow you to mount your Z to it’s lowest setting. The Z mount has a machined recess for the Z on one side only. Because of this, I can’t lower the Z, low enough to use standard surfacing bits.
