Ripper 3 flatten bit adding tool to Carveco
I am new to the CNC world and Carveco, so I just wanted to make sure I am setting up this tool correctly.
I recently purchased the Ripper 3 to help with flattening some boards on my cnc. When reviewing the specs online this is what I did when I added the tool to Carveco. Just wondering if anyone else has purchased this bit and have added so I know I did it correctly.
Ok I talked with High Country Support and have made the adjustments. They suggested using an End mill instead of Radiused Engraving bit. When looking on Carveco’s software it looks like all End mills are slot drills so that is what I have adjusted it to. I also lowered my feed rate to 100 in per min instead of the 165 to make sure my system can handle it.
