per the instructions:
“Install the Non Wheel legs to the QCW Frame using the outside Frame End bold that you removed in step 1”
The removed bolt is to short to fit through both plates and be tightened
from user braddo in December 2021
“The rolling folding stand has two plates on each corner that flank the sides of these blocks. The bolts with lock nuts you see here holding the blocks to the tubes are replaced with longer ones that go through those plates, the blocks and the tubes. The frame is far beefier than I expected from the photos.”
So I need to buy my own longer bolts? Are they included anywhere? Thanks
