I have a problem with Set Position. Every time I use it in imperial units I can’t put the decimal point in until i put numbers in, then I have to go backwards to put the decimal. Can you help?
Thanks
Claude
Thanks
Claude
I have noticed that also, it’s a RPITA. This should be a simple fix, if I could build the firmware on a Mac it would be fixed, but alas, you need windows to build and I hate Windoze.
