Skip the GX12-6P connector and go direct?
Hey Alan,
a connector is to be able to separate the components, and I see that it would not have the space needed on your setup. And yes, I don’t like these connectors, I prefer industrial circular connectors that are crimped, not soldered, and have gold-plated contacts, from Phoenix :slight_smile:
In the case you omit the connector, you simply skip the connector column in this table and wire the internal Masso G3 pins directly to your WJ200 VFD pins:
