Does anyone have a photo of the wiring from the gx16 cable to the wj200 they could share?
Hey Brenden,
what do you mean with GX16 input?
Gx12 sorry. From the display to the Vfd
You mean from the Masso G3 Touch CNC Controller to the VFD, this is here under FAQ:
Directly at Masso Documentation there are also these pages which explain what the cables are for:
For the other cable, from VFD to the spindle, see
and of course:
as well as:
Thanks. Iâm familiar with those, looking for photo documentation or YouTube as people have done for the HY.
Hey Brenden,
I donât have a photo documentation (although planned), but here you can see the WJ200-specific pins that you have to use:
| Internal Masso Spindle Control Interface | Function | GX12 6-pin connector on back of Elite Masso G3 Touch (internal wire colors) | Wire color and pin on | VFDs Hitachi WJ200 or Omron MX2 | |
| G1 or G2 or G3 or G4 or G5 | GND | pin 1 black | pin 1 black | goes to | "L" |
| SC1 | 0-10 V Analog | pin 2 red | pin 2 red | goes to | "O" |
| SC5 | CW | pin 3 yellow | pin 3 yellow | goes to |
â1 (FWD)â |
| SC4 & SC 6 | Common | pin 4 green | pin 4 white | goes to |
âLâ |
| Not connected | pin 5 white | ||||
| SC7 | CCW | pin 6 blue | pin 5 green | goes to |
â2 (REV)â |
Important: The short bar must be on âP24â and âPLCâ, not on âLâ! (image on the left is correct).
On WJ200 settings, there also must be:
A001 (source of motor speed command) set to â01â (analog input) and
A002 (source of run command) set to â01â (control terminals).
â Source: Hitachi WJ200 or Omron MX2 manual
All this applies to both Hitachi WJ200 and Omron MX2.
Please note hint from Onefinity manufacturer:
Thank you that is helpful, no pin 4 then?
Hey Brenden,
oops, there is a line that is lacking. Sorry! Goes to âLâ too. Will correct the table above tomorrow.
EDIT: I corrected the table above.
So only the green pin is left out?
Hey Alpha1172,
however the VFD you show is no Hitachi WJ200.
Welcome to the forum!
Hmm I have the wires correct but I canât get this to spin the spindle. It makes a beeping sound when I hit spindle ccw or cw, do you know what would cause that?
Hey Brenden,
canât say without more information. The settings above for the VFD are only those relevant for the function that comes from CNC controller. I would check, do you have programmed all necessary parameters inside the VFD according to the manual. Does it show an error code, then you could look it up in the VFD manual.
Usually I would test it with âM3 S8000â in the manual data interface.
See also:
Sorry got to go now, itâs 4:29 AM here
Yeah the one post was asking aboht the HY so thatâs why I posted it.
Also ur posts have helped me out so much!
Got it working, thanks for the help
I have every parameter correct but I canât get the rpm up. The f001 reading which I canât change is at 3.3. I have my spindle settings all at 400hz. Any thoughts? Is it normal to not be able to control the rpm via the display?
I have success with A002 being set to 002 and I can control the RPM from the vfd and have A001 set as 01 to be able to start from the Masso display, but Iâm wondering why I canât do both as 01 from the display?
Hey Brenden,
of course you can set âA001 â Speed command source settingâ to â01â â âControl terminal â The active analog input signal on analog terminals [O] or [OI] sets the output frequencyâ, and then, if it is wired correctly as shown above, the MASSO G3 will control the spindle speed with a g-code command like âS6000 M5â.
Thought Iâd revisit this. It was was software, easel not exporting commands and I was on Mac so the only option at the time. Vertic, Carveco obviously fine.
