Huanyang VFD wiring to Elite Masso G3 Touch
All, I have an HY 220v 2.2kW spindle and VFD. Can I connect my HY VFD to my Masso touch screen(Elite Forman)? I do have the VFD connection on the underside of the touch screen. I have searched and searched but found nothing.
Hey Greg,
what you mean is probably this:
in conjunction with this:
See also here for more information
That looks like what I need. Thank You. I am not he best cable maker… Do you know anyone that makes these cables?
Hey all,
Internal Masso G3
Spindle Control
Interface
FunctionGX12 6-pin connector
on back of Elite Masso G3 Touch (internal wire colors)
Wire color and pin on Huanyang
HY Series VFD
G3GNDpin 1 blackpin 1 blackgoes toGND
SC10-10 V Analogpin 2 redpin 2 redgoes toVI
SC5CWpin 3 yellowpin 3 yellowgoes to FOR
SC4 & SC6Commonpin 4 greenpin 4 whitegoes to DCM
Not connectedpin 5 white
SC7CCWpin 6 bluepin 5 greengoes to REV
Notes:
CW = Motor clockwise rotation (forward)
CCW = Motor counter-clockwise rotation (reverse)
VI = Voltage input (controls spindle speed via 0–10 V analog voltage)
DCM = DC common
GND = Ground
Image: Huanyang HY Series Basic Wiring Diagram (Source: Huanyang HY Series Manual)
Image: --Source: Spindle VFD examples → Huanyang – Masso Documentation
Image: – Source: VFD/SPINDLE wiring schematic for Elite Masso machines
My spindle control port7 doesn’t have any wire, is that normal?
Hey Waynec,
S7 is for counter-clockwise rotation of the spindle. That is rarely used when milling wood, soft metals or plastic, because most bits have their cutters working in clockwise rotation.
Welcome to the forum!
What is the blue wire connected to port 2 and where does it come from, I want to enable CCW rotation.
The white wire from the aviation connector in the Masso control box needs to be connected to pin 7 for CCW to work. The wire is probably tied off in one of the bundles of wire.
Thanks again, do you know off hand if I need to change any parameters in the VFD to enable CCW or just do the wiring as discussed?
Thanks, Pat
I did not have to change any parameters.
Just got it hooked up and all is working as it should, now for the RapidChange ATC tomorrow.
Thanks for your help.
Pat
