Does anyone have a source for empty plastic bit cases? I haven’t been able to find anything on Amazon or elsewhere.
Thanks!
Thanks!
Do a search for router bit case and you should get lots to choose from. You can also make a custom case if you want. Rockler sells plastic inserts to hold the bits.
I found a few sources under search “plastic end mill cases” but this one in particular looks somewhat promising as being US-based.
https://store.cleartecpackaging.com/clear_en/grp.html?Item=GRPM100313L07
That looks to be exactly what I am looking for, thanks! I never thought to use the term “end mill”. ![]()
No worries and thank you, too, because they’re something I’m also going to need in time and you helped me move beyond my typical procrastination to actually source 'em. ![]()
I received my end mill grip packs today from Cleartecpackaging.com. (which is actually Beckett Packaging) They are exactly what I was looking for. In case it helps anyone else down the road, here is what I ordered:
GRPM080250L02 - these are the 1/4" caps in red
GRPF080079C00 - these are the cases 5/16 X 3.11 (8 X 79MM)
Minimum quantity is 20. Combined it was $24.24 plus tax and $9.60 for USPS priority. I ordered Sunday and they arrived Wednesday.
I also ordered some 1/2" caps and cases which ran me about $33.
