In Aspire or using freeware softwares in internet is possible to create hlaftoner pictures and a gcode accordingly.
Is there any video/image or text about it tocheck how precise the job will be?
thanks
thanks
Hi David
I’m using this toolpath since one year on different machines and I realized that the same file can have different results on different machines. I was wondering if there is a video showing it on oneinfinity to check it’s precision in this toolpath since it’s very demanding for cnc.
For example on a simple stepcraft z zero must be 0.2 mm lifted or deeper holes will collapse one on the other.
Thanks.
Provided you use either the touch-probe or paper method to set you z-axis height, you shouldn’t have any trouble getting the correct depth as the 1F machine is very accurate.
