I am using Vectric V-Carve Pro and I have noticed that my actual carve times are typically about double what VCarve estimates. I do have the Onefinity as my post-processor. Which is wrong, Vectric or the Buildbotics controller and is there anything that can be done to speed the process?
On the screen where you see the estimated time in Vetric, there is a box that says Scale Factor that you need to adjust until the time shows is close to actual. Also enter the rapid rate for you machine. do those two things and your estimates will come a lot closer to reality.
