Stall operation on 1F 50mm Foreman
Hello. I just completed the assembly of my new machine. I know on the non-Elite model, the stall current is used when homing the machine. But on both the X and the Y axis on my unit, when the machine gets to the end of the travel, it sounds line something is skipping for a moment. Is that normal? Or should the machine simply travel to the end of the axis, hit the end and stop all movement? Thanks in advance for your help on this
Hey Simo733,
stall homing works this way. It bumps against the end of the axis travel, this can look and sound strange for persons who see it for the first time.
Stall homing, which is the Onefinity Original/PRO/X-50 stock method to tell the machine that its carriages are at machine zero coordinates, is of poor repeatability, you will hardly get the axes homed at the same position twice. But this is not really important if you consider that you only home once after startup of the machine, so that the machine knows where its carriages are (they may have been moved when the machine was off), and then for further positioning, you probe workpiece zero with XYZ touch plate or zeroing manually which can be very accurate, also regarding repeatability.
If you want perfect repeatability at the homing step on startup, you can retrofit limit sensors.
Hello Aiph5u. Thanks for the info. I didn’t really think there was an issue (at least I was hoping there wasn’t an issue), but thanks for confirming. Have a great day!
