Tiling problem!
I cannot get my machine to tile properly. I have watched “how to” videos on Youtube and have followed directions. However… when I move my work piece to cut the 2nd tile - and I move the work piece to the bit never moving the bit, the machine DOES NOT start the 2nd tile cut where it should be, which ruins work every time I try to tile. I never had this problem tiling projects with my old Mach 3 machine. I use Vcarve Pro version 12. Suggestions?
Hey Raykocj3420,
have you checked that your machine is
  1. rectangular (“squared”) (bar gauge) and 2. coplanar (“not twisted”) (fishing line method) .
If the machine is not accurately rectangular (“squared”) all your workpieces will be a parallelogram. Often this is the cause when tiling fails.
Raykocj,
If Aiph5u’s fix doesn’t work, could you describe how the tiled cut is off? Is it just a few mms, or wildly off?
Hey Aiph5u!
I will check my machine squareness with the fishing line method and get back to you with the results.
Sailor Mike!
I should have taken a picture of my last failed project before I burned it. I will do another project after I check my machine for square and provide a picture.
Thanks for the help guys!!
Hey Raykocj3420,
The fishing line test does not check rectangularity (“squareness”) but the coplanarity (machine not being twisted). The check for “squareness” is the comparing diagonals with a bar gauge check and then milling a rectangle with a v-bit on the outer dimensions and repeating the identical diagonals check.
OK guys - I have checked the squareness of my machine with the bar gauge method (made my own from a YouTube video). My machine is 1/8" out of square no matter how many time I re-check it. I have an Elite Forman with a QCW frame. I have loosened all 16 bolts holding my machine to the QCW frame, did the back to front tightening process with the gantry and I am still 1/8th out of square. I have asked Onefinity if this is within their tolerances however they keep asking for a detailed video, I have sent photos with the bar gauge results. So - do I live with my machine 1/8 out of square?
Hey Raykocj3420,
1/8"
That’s 3.175 mm. If it’s the QCW Frame that is not square then then it would be very annoying! Because there is no adjustment means.
I would not tolerate this. It prevents precisely rectangular workpieces and tiling.
Did you check that both Y rails (from black anodizied block at the rear to the one on the front) are identical in length on the left and on the right Y rails? You can check this with the bar gauge too.
I would not use the back to front tightening process but after having loosened all bolts, I would push the one side away from you and pull the other side towards you, and have a second person to quickly fix the bolts.
Also don’t forget to loosen the bolts of the X rail! It could manifest an out of square geometry.
