Top Left Work Origin Problem
I have the latest VCarve Pro and Masso software, I need to have the work origin at the Left Top corner of the workpiece.
I set the origin for the job accordingly in Vectric. I then use the Touch Probe block at the Top Left corner also. However the Work Origin is offset somehow from the actual origin.
Not sure what I am doing wrong.
If you used to probe from the bottom-left, you need to swap the X and Y Offsets in the Masso Probing screen because you have now altered the orientation of the probe 90 degrees. Also make sure the Probe Diameter matches the diameter of the bit in the spindle.
Measured the Top Lip on my Touch Probe and entered that in the Y Offset. Worked perfectly.
Thanks so much for the insight. Appreciate your response.
