Hello all.
I was carving and got too aggressive and errored out my spindle. When i follow the steps to recover from line in my masso the x y and z all move however the machine begins to move and the spindle never starts. I have cleared the error from VFD so all should be good. I could manually turn on VFD to make spindle run but would really like to know why spindle is not starting when using recovery steps attached. Any ideas?
Thanks in advance
Thanks for the info.
My machine starts moving when bit has contacted the z height and the spindle has not started. I let it go and it went 4 inches scraping along and spindle never starts. Luckily i had a 1/2 inch bit in or the bit would be toast. I am hoping someone knows a workaround.
Rusty
I am going to try this since this is the line I need to start from and see if it works.
N79040 S15000 M3 X-5.3405 Y5.2356 Z-0.4908
I had tried to find that information as I thought I had remembered reading about it, but the Masso forum search function just wouldn’t locate it - thank you for sharing it.
Awesome. It was hard to find but glad i am not insane becuz i did the same thing multiple times expecting a different result. Lol
Here is a better explantion from Peter with Masso at the end of the thread.
https://forums.masso.com.au/threads/mill-jump-to-line.3097/post-33074
Hopefully helps somone if struggling.
