The toolpath G-Code generated by Carveco includes a G21 command which sets the units to metric. Is there a way to configure Carveco to set the units to inches (G20)?
You have to set it when you are creating your model size or you can go to drop down menu under model, click on set size and you will see you have a choice to set it to inches instead of mm. Its in the bottom right under Units.
When you create a new model the units are at the bottom of that drop down window. That is what tells the software to use a G20 or G21. If you do it after you made the program after you change it you will have to regenerate the program for it to change it in the program.
