Vectric Aspire or VCarve Batch Toolpaths
Has anyone any idea if it is possible to batch toolpaths in vectric aspire / vcarve?
I have about two hundred rosettes and another hundred ceiling medallion (models) that outside of their design differences might be using the same Roughing / Finish / Profiling process based on similar dimensions, for example a rosette that is 4" x 4"
Does anyone have any experience doing batching or know a foolproof way of simplifying this otherwise tedious task. I’d like for each rosette file, to be saved with their toolpaths, so then I can go into each one manually and do what ever necessary tweaking needs to be done -
Jenn
Does this help? How to Combine Multiple files w/toolpaths into one - Vectric Customer
Hey Joe,
This could very well do the trick… I’m going to try this, thanks! :slight_smile:
