Wasteboard surfacing question
Hi folks.
Newbie here and I’m trying to surface my spoil board. I understand the process and I’m trying to use Carveco Makler to create a toolpath. It’s all set up but I have no idea how to add my surfacing bit to the database also I can use it. I got a Binstak 2-1/2" surfacing bit from Amazon.
I’ve gone through Carveco help and see how to add tools to the database, but don’t know where to get the info from or download it. I hope this makes sense.
Hi John,
I’m not familiar with Carveco, but it sounds like you will need to manually enter the specs for your surfacing bit into the database since there are no specs given or available for it.
Thanks, Bill!
I think I’ve figured it out. I downloaded the Bits & Bits complete tool database. I found a similar bit and adjusted the specs to fit my Binstak 2-1/2" surfacing bit so I think it should work fine.
