does it make a difference which direction you cut, left to right, right to left, front to back back to front. In what situations would you cut in one direction vs another. thanks
It matters a lot more (1) whether you are climb cutting or conventional. and (2) are you gong with the grain of the wood or against. and (3) What type of material are you are cutting. There is no easy answer to the question you are asking. It all depends on the answers to these questions.
I’m new to this. I’ll have to read up on climb and conventional. hardwoos, walnut,maple ,exotics. will have to check grain. thanks
no problem there are lots of articles both on the forum and elsewhere online about climb cutting vs conventional amd look up routing wood in general and cnc routing in particular.
have a great day.
