Hey folks - there are a few threads mentioning that it’s easier to use the “from below” frames. It totally makes sense that one need only get the dimensions right then put a wood screw in from the bottom and you’re good.
However, how are you getting under there? Would one be lifting up the whole machine? Disassembling it and then just installing wasteboard into the frame?
Then to the question posted. I’m excited to try the wall hanging approach and have ordered both the frame and the wall brackets. But, seems even more difficult to imagine screwing waste boards in “from the bottom” since, I think one would have to completely dismantle and then “remantle” to use that.
Wall mounting in general I assume has it’s challenges with holding the work piece up there whilst using whatever clamping approach but curious what folks think about top versus bottom loading the wasteboards in that configuration
