XYZ probe incorrect
If you are using the
Onefinity touch plate, then if it is anything like mine, to say it is accurate is an understatement, it is out by at least 0.5mm (.0197’) in various directions. I have marked various positions on the plate,
which are known values, and use these.
It should not be inaccurate, you can set the dimensions of the touch plate on the Masso.
