Y axis getting stuck half way (solved, adjust stall homing)
Y axis seems to be having issues - when we try to “HOME” it, the Y axis stops or gets stuck half the way but the sounds of the motion keep going.
We have inspected the wires, and so far everything seems to be intact.
Have you tried to move the Y axis by hand to make sure nothing is binding?
Can you see the motor and coupling while it’s moving?
What machine type do you have? Most likely buildbotics and you simply need to adjust stall homing:
