Z axes not going deep enough
Hello, I am needing some help. I load my g-code and begin the carve. I am cutting out a circle, cutting all the way through. My material is .221 and my cut depth is .221. When the carve is done, it has only cut about .102. I have looked at my g-code in note and the z axes depth is set to .221 but it did not do it.
G0 Z-0.14100
G1 X9.28217 Y2.37686 F30.0
G1 X9.32593 Y2.29944 F30.0
G1 X9.37347 Y2.22421 F30.0
G1 X9.42465 Y2.15146 F30.0
G1 X9.44039 Y2.13124 F30.0
G1 Z-0.22100 F9.0
G1 X9.47928 Y2.08127 F30.0
G1 X9.53738 Y2.01385 F30.0
G1 X9.59866 Y1.94940 F30.0
G1 X9.66302 Y1.88800 F30.0
G1 X9.73032 Y1.82983 F30.0
G1 X9.80042 Y1.77502 F30.0
G1 X9.87311 Y1.72375 F30.0
G1 X9.94821 Y1.67609 F30.0
G1 X10.02560 Y1.63217 F30.0
G1 X10.10501 Y1.59213 F30.0
G1 X10.18631 Y1.55600 F30.0
G1 X10.26929 Y1.52390 F30.0
G1 X10.35376 Y1.49591 F30.0
G1 X10.43942 Y1.47211 F30.0
G1 X10.52628 Y1.45258 F30.0
G1 X10.61389 Y1.43729 F30.0
G1 X10.70215 Y1.42630 F30.0
G1 X10.79086 Y1.41971 F30.0
G1 X10.87982 Y1.41745 F30.0
G1 X10.96875 Y1.41956 F30.0
G20
G90
G0 Z1.50000
G0 X0.00000 Y0.00000
G4 P0.1
I am trying to find out what I am doing wrong or if maybe my machine is messing up. I have the bit set to 1/8 inch bit and I use the probe block. Can someone point me in the right direction? Thanks
Couple different things can cause that.
Check that your material thickness is set correctly in your programming software. For example, If your programming software thinks 1/2” plywood is loaded, but you actually have 5/8 plywood on the bed, the cut won’t go all the way through.
Next:
When you set Z0, make sure you aren’t accidentally setting it above the material. Your material might not be sitting flat on the table, or the cutter might not be sticking out as much as the controller “thinks” it is.
Next:
It’s possible when you run the program, the cutter is sliding up into the collet. This can be identifies be taking a close look the z height of the cuts, and you’ll see evidence that the z height is changing during the cut.
I had a similar problem until I calibrated the Z axis, via the Masso wizard on the F1 page for Z. When I cut my first project that had a facing/flattening toolpath where the Z dimension was critical, I discovered it was off by .5 mm, but the previously calibrated X and Y generated nearly perfect results in that same cut piece; 50 x 20 x 19.46 (should have been 20). The wizard takes you through a short process of asking you to tell it how far the axis really moved (digital calipers are best here, as you measure the travel from starting point to ending point) in a given move.
Since this is an Original/Pro machine the Z axis configuration needs to be set by following this link:
how-to-reset-the-configuration-to-defaults
It could be that you have the wrong default selected for your type of Z-slider.
To verify that your z-axis is set correctly, jog the machine so the bit is just off your material. Lower the bit until the control indicates zero height. Verify that this is correct. Assuming it is, lower the bit further until you reach the depth of 0.221 and verify that this is what you expect. If it is not, then your control settings for the z-axis are not correct. This is likely where your problem is.
hello and thanks for all the replies. I thought I had updated this but it appears I have not. I ended up taking the bit all the way down till it stopped and noticed the bit did not go down far enough to cut all the way threw my material. I was using a short 1/8 bit and just slid the collet up on the bit some. That fixed the problem, my only question now is why did it not tell me that my depth was not reachable, I guess? Maybe the machine cannot tell that I don’t know. thanks again for you all’s replies greatly appreciated.
I noticed Masso does not pre-screen the program for any soft home conflicts. That would be a nice feature.
It seems to look ahead maybe 50 lines of code or so. It will trip a soft alarm well before the action is requested- which makes it a little more difficult to diagnose.
