Yes, this is normal. The home is found by an (i think) amperage spike threshold that is adjustable. Here is the over-under explanation. Essentially, it will go away when you load a file and zero your XYZ if your tool paths are correct.
newbiee
(Preston Bowden)
2
Related topics
| Topic | Replies | Views | Activity | |
| Z axis homing issue | 5 | 4228 | September 28, 2021 | |
| Z problem with first time homing not zeroing (solved) | 6 | 2315 | January 16, 2023 | |
| Z axis ESTOPPED switch not found when homing | 14 | 2665 | January 25, 2022 | |
| First time homing errors | 2 | 1000 | February 28, 2022 | |
| Z axis position error | 11 | 2088 | April 13, 2023 |
