Z Axis Over! Message
When I home the z axis it goes thru the process and give me a message that says over! Does this mean it is homed? Watched every video on YouTube to see if I could answer without posting but no such luck. Has anyone else experienced this or is it supposed to do this? Fyi I did adjust the stall homing settings both current and voltage but it made no noticable differance. I have since set them back to default. Thanks in advance for any input.
Completely normal. Infact, that exactly how it should be until you zero your z axis.
And so it is. Worked perfectly, thanks again!
