Z axis under error
I keep getting a Z axis under error, 0.825 ish. I zero out on the machine bed, the tools is on the bed. But I am getting the error still.
My current travel Z height is 1” above the material, .65
I have enough room, more then enough travel left to go down and up. Cant figure out what is causing the issue
The G code is generated on Aspire 12.
leaf coaster.crv3d (3.4 MB)
So I cut a few things with the under error today… no issues not over travel ECT. Still says under
I did just update from like 1.1 firmware to 1.6
I noticed this one has a couple new menu’s for the z axis and such in the motors.
Running the buildbotics controller btw
Could a setting from this be off?
For an update jump that big you probably have to reset the config:
How To Reset The Configuration To Defaults (BB Controller) (FAQ)
Also updating from 1.1.x it’s recommended to do a reflash:
https://forum.onefinitycnc.com/t/onefinity-cnc-firmware-1-3-1-12-15-23-x-35-x-50-machines-w-buildbotics-controller-outdated/24005/5
OnefinityCNCOnefinity CNC Official :white_check_mark:Leader
Dec 2023
If you were on either 1.0 or 1.1.X family of firmware, it’s highly suggested to reflash the os rather than update to remove any lingering 1.0 or 1.1.x code.
